couple of queries, guys.....situation is a 1st floor flat (my son+gf`s first home)Needs an electric shower and therefore a new Cons. unit. Have read here that the meter tails could be disconnected with a 100a.D/P switch.....but have also been told that ONLY the company supply fuse and meter should be in the wall box on the outside of the building Also the "tails" are a length of armoured cable from the meter running hidden in the fabric of the building and appearing in the fusebox cupboard in the flat....the armour wire is the earth back to the company supply.......will this be adequate I`ve a feeling that a separate earth wire should be run........this I can do before I re fit the bathroom.....would the 100a isolator be ok. in the fuseboard/cons. unit cupd...or is it necessary at all. can`t even get hold of my regular sparks to ask him let alone get him to come and change the CU from old fuse box. so any advice would be appreciated..before I build things in that he will need to get behind etc
