Hi all,
This is something I should have researched ages ago, and now we are in the position of being able to replace our service pipe (new driveway) I thought i'd ask a few questions here.
In the picture - the currrent mains water set-up->20mm MDPE Service pipe (not 25mm...) into a 1/2" stop tap, which feeds 15mm copper for the mains cold and an "up"converter 15mm->22mm Worcester Bosch Combi feed.
The hot water flow rate has always been ok - but not amazing, but now we have a growing family it will start to take more demand.
I suppose the answers to my questions might help decide whether I upgrade the service pipe to 32mm since the drive is being dug up anyway or will i get some benefit from changes at the stop tap pictured.
Q1: Is there any point in replacing this 1/2" stop tap for 22mm version now, instead of a new 32mm service pipe?
Q2: Does the current tap look like the correct component, or is it just a "brass tap" and potentially restrictive?
Q3: When the 22mm copper Combi feed was installed, it started as 15mm - should I bring this back (as 22mm) to a new 22mm stop tap to improve things?
If I do end up replacing the service pipe, I would prefer to only buy one new stop tap, but if you guys think I might get better performance for a lot less cost, i'll explore that first.
Thanks for reading
Thanks for reading
