If a fusebox with existing supply tails of 16mm T&E is replaced with a split load CU, do the tails have to be upgraded if the main fuse is 60A ?
The supply for another fusebox supplying the storage heaters is fed via 10mm T&E. (there are 4 heaters, each fed via a 15A fuse)
The length of both existing supply tails is about 6M.
