1- Could anyone let me know what size should the meter tails should be on a 35mm supply on a 100amp fuse from the DNO, also the earth cable size to the earting rod? TT System!
2- Does a main double pole isolating switch exist (RCD or otherwise) where meter tails enter from meter, but on the supply side have two outlets (2 positive & 2 Neutral) rather than using a Henley block to split the tails. There is no isolator at the moment but want to run a SWA submain from a swithchfuse and thought that rather than using a Henley block to split the supply an isolator would be useful.
3- The meter states 80amp on it although it is protected via a 100amp DNO fuse, is this OK?
submain
submain
