meter tails in 25mm conduit
13 Oct 2003
Does anyone know if a pair of 25 sq mm 100A meter tails (and 16mm earth) will pull through 25 mm plastic conduit? It's got 2 bends in it. Assuming 25mm is the OD of the conduit it looks possible but tight to me. What can be used as a lubricant if this would help? I could thread the tails through the individual bits before joining if that would help. :confused:
you are only supposed to use 40% of a conduits capacity
why not put in 40mm push fit waste pipe? you can put the bends on as you pull the cable through
