Good Morning all,
Hope you all had a good Christmas.
Right, im getting a REC 2 isolator fitted next week and been told the tails will need upgrading. At the minute I have 16mm which I know is good upto 87 Amps so im guessing my main cut out must be 100A and the upgraded tails will be 25mm.
From what I was lead to believe, from the sparkys de-brief, was he is going to disconnect the CU and put those into the REC2 but then fit 25mm tails from the isolator back into the CU. Now I cant see what the point is but I never questioned it. Surely upgrading tails means it goes back to the cut out, or at least the meter as the name METER TAILS suggests.
Regards
Regards
