A couple of quick questions from a relative newbie
1) What's the best tool for cutting and stripping meter tails?
2) Where do you strip off the outer sheath/insulation to and why? I've seen all the following but am undecided what is best.
a) Strip off where the tails enter the CU, leaving the inner colours visible from the entry point to the main switch
b) Strip off at the same point the inner is stripped at the entry to the main switch
c) Strip off a short distance (say 1cm) from where the tails enter the main switch, leaving a short length of visible inner insulation but fully protected throughout the remainder
