Metric doors
16 Jun 2007
Angus
Hi, I'm looking for some help in finding 15 pane obscure glazed pine doors.
The size I require is 2040 x 726 x 35mm. All the sites I've found so far have the depth listed as 40mm or only list the height and width.
Is 35mm the standard depth? And does anyone know where to find them? eg any web sites or B&Q, Focus etc.
Any help/advice is greatly appreciated.
Cheers
Thanks for the replies!
Ah well, trust me to buy a flat with abnormal (aka expensive to replace) doors. Looks like they're just gonna have to stay in place for the time being.
Or move the door stops, unless you have rebated linings
Jason
If your door stops (abutments) aren’t rebated it should be fairly easy to move them as Jason suggests, I’ve done it on most of the doors on the current refurb. I’m doing. Use a stiff scraper & hammer it in under the stop at the bottom & work your way up to the top, gently easing it away from the frame. You should even be able to re-use the stops after a little clean up as long as the chippy hasn’t gone overboard on the original fixings but you will probably have to strip all the paint & start again.
Now you're just going over my head! :confused:
I'll remeasure the depth when I'm next at the flat and check it's not 40mm. I hope I made a mistake the first time!
