Hi, new unit we have took on has a mezzanine floor. The construction is steel.
There are wires running along some of the steel sections. (lying inside the void) but i cant see any earth wire directly connected to the mezzanine. It is bolted to the concrete floor tho so would this act as a earth? (concrete is direct to earth/soil with no dpm)
Question - should the mezzanine floor be earthed? If so does it just need one earth at some point as all bolted together? or does each metal joist need bonding separate like the pipe work below a boiler? (each metal joist is bolted to a RSJ so all metal is connected together)
