Micra front heat shield rattle
7 May 2011
Durham
Near the shield are 2 rubber sheathes for the clutch cable and gear change.
Can i cut it off or should i try something different like jubilee clips?
Is this the shield that covers the catalytic converter? That actually can be done away with, but whatever happens you don't want the clutch cable drying out as it will get very stiff.
See how you get on with jubilee clips - or stiff copper wire if you prefer.
John :)
Not the cat, the section down straight off the manifold, passes oil sump.
Yea I'll try jubilee clips
Sheathing is just 3 inches away from the exhaust so would prefer leaving it on. Cheerz again mate
Ah, the tin one that covers the exhaust manifold.....rusted through around the bolt holes, no doubt?
This could be really awkward to tie back on, but if you can shift the 10mm bolts - if there's anything left of them - a new one could be worth considering.
If it falls off, I wouldn't worry too much!
John :)
