Micra
20 Feb 2006
Hampshire
Had the inside of my new shape Micra valeted now the air bag senser flashes. Also the back seat is now very difficult to slide hes says he tried to tip the back seat which is on runners! Any sensers around there. Any ideas Thanks
Was it an inside and out valet?
May have go one of the wheel sensors/connectors wet with the jet-wash :confused:
I know with some Renaults the airbag connectors are situated under the two front seats. Not sure about Micra's? Might be worth checking under seats, see if there's a connector that has come loose?
Can you reset your airbags? Turn the passengers side one off & on. Some cars you are able to switch the airbag off on the passengers side, if your carrying a baby in the front in a baby seat.
My airbag warning light started flashing on a new shaped Nissan Micra. The local dealer ran the diagnostics (£44 plus VAT), found that the passenger seat sensor circuit had a fault, and believed it was a connector under the seat that needed replacing (£33 plus VAT), the dealer thought it would be a good idea to replace drivers side connector at the same time (another £33 plus VAT), and this took half an hour (£55 plus VAT). I took a look when they had finished, and realized that this connector is flexed every time the seat is moved, and the wires are not really tucked away, so a car vacuum nozzle could easily disturb them. I don’t know which is the most upsetting, that it cost over a hundred pounds to fix a simple loose connection, or that the design is so fragile. I really hate cars right now.
