Mum lives in a 3 story house. C/H has been run in plastic micro bore ( I believe 10mm ) Boiler ( Potterton suprima HE, recently serviced and informed in good order) in ground floor kitchen. Grunfloss 15/60 pump in a/cupboard on next floor up, with a large extended lounge on lower ground floor. There is a manifold on top floor feeding 6 rads, and manifold on lower ground floor feeding 5 original rads, and 2 add-ons. One has it’s own feed on the manifold, and the other must have been added on to an existing (rad run) all run under the hardwood flooring. Upstairs heating is good.
The problem is the rads on the lower floor just about get luke warm. The add on with no dedicated manifold connection only getting luke warm after heating has been on for about 3 hours.
From previous posts I have read from the past 10 years, I realise there are a variety of reasons for this problem which need to be looked into.
However my question is, would for example a W/Bosch system boiler, or similar, being sealed and pressurised provide better circulation than the existing open vented system.
I realise curing the problem should be the first course of action.
Thanks.
Thanks.
