micro bore pressurising safe?
prw
19 Jan 2006
Essex
Hi
My plumber is suggesting sealing my mirco bore radiator/boiler circuit and fitting a pressure vessel so that it is mains feed. Then fitting a megaflo cylinder for DHW. Loft is dry at the moment. Another plumber has suggested a header tank in loft.
I have only experienced micro bore that is gravity feed, which should i go for?
If you have time please respond to my previous post as well.
