can any one help i have a micro genus boiler and the yellow light keeps coming on i have had it cleaned and the only way it works is if i keep the front off but it has now started to come on for 2 mins then go off for 5 mins.
If you weren't planning on dying this afternoon, you should turn the boiler off.
Call a Corgi registered Engineer. It's a common fault but not one you should try to fix.
