We recently made an offer for a bungalow which has been exended and has two c.h. systems, the old part a pressurised system with normal sized pipes to the rads and the new part a microbore system, which we hadn't noticed but was pointed out by a builder friend who inspected the property for us. There are 2 boilers, one in the loft and one in the garage, neither condensing, and two cylinders. Our builder has warned us off a microbore system as he says they always block up eventually and there is no way of cleaning them out. There is no rad in the kitchen; only a kickspace which is defunct - I don't like them anyway - and no rad in the hall, where there is a grill from an obsolete warm air system, so we would need to install them. Our builder says we should replace the pipes to the normal half inch (or whatever the mm equivalent is), which wd mean bringing them down the walls as the floors are all solid.
Do you agree that microbore systems are a no-no and would lead to problems. We have had more than enough with our system here and don't want to have it all decorated and then have problems.
Advice appreciated.
Advice appreciated.
