I have another question. The Ch pipes I beleive are Microbore which at ground floor run into the walls and at the 1st floor into the floor boards. Can you purchase Radiators for Microbore systems and if so are they the same as for normal CH systems or do they need modification? I have heard that Microbore Rads have tubes which run into them from a one way valve, the other end being blocked. Also how easy are they to change? Many thank.
