I moved into a house where the heating system used microbore pipes. The radiators were tiny, and I suspect the job was done by the previous owner as a DIY job. The house does not heat properly.
I have bought larger radiators and spoke to a few plumbers - but nobody seems to want to job.
1 chap said the microbore pipe should be taken back to 15mm pipe in order to supply larger radiators downstairs.
He also said that if 1 large radiator is fed from microbore pipe, this cannot then be extended to supply another large radiator in the next room because it will just 'skip it', and not heat up.
The 2nd plumber said he would just connect both large radiators to the microbore and it would be fine
Someone is fibbing - but neither ended up wanting the job.
Who was fibbing?
Who was fibbing?
