aaronb said:I've just moved into a place with a microbore CH system. Having never seen it before, I just wanted to learn a bit more about it. Why is it used? Is it any good? Etc.
Yes its good and it is used because it has a smaller bore than the standard 15mm pipe and is used because its a smaller bore.
Agile said:Its fitted to do the installation quicked and cheaper! There are NO advantages. It was promoted during the 70s to lower the price of an installation. Many have now been repiped in 15 mm.
The 10 mm version works reasonably well but the 8 mm one is very prone to getting blocked by dirt and is often difficult to impossible to power flush.
Best avoided if you have any choice!
Tony
weareleeds said:I hope you don't have any large double rads as microbore will not heat them up properly
bobthebender said:You talk some cr*p
I don't think you have a clue about microbore.
rob884 said:bobthebender said:You talk some cr*p
Then why not tell us?
gas4you said:except microbore is not very good for powerflushing
