I removed a double skinned radiator on my microbore system in order to repair the wall paper behind and for general decorating purposes. The Yorkshire Imperial combined inlet /return valve had a spiral copper conduit which led into one of the two radiator skins making it virtually impossible to separate the valve from the radiator In the process of disconnecting the valve from the radiator this conduit parted company with the valve. On reconnecting, the radiator is now not functioning as the flow from the inlet valve is not getting into the radiator and is instead disappearing out of the outlet.
I presume that I require a new radiator fitted with a new valve and its integral conduit? Any suggestions as to suppliers as microbore is not a common DIY system? To attach this to my system can I shut off all the other radiators and isolate the hot water tank thus confining any spillage to that in the feed/ return to this radiator only?
