I need to move a radiator in a timber frame house. There are 6x2's all over the place so I have come up with the following idea and need some advice.
The old position is on one side of the back door, the new position is on the other side. It is obviously a downstairs position.
The pipework is 8mm microbore and I am going to lay pipes from the bottom of the drop to the door, then into a shallow channel in the concrete floor, then back up and into the studwork.
There will be a 90 degree angle down then another to run the pipes under the door then another up and finally one more (four 90 degree angles in all)
____ ____
-----|_____|-----
Will all these bends cause a problem with the flow in 8mm microbore?
____ ____
-----|_____|-----
