microbore
cjp
18 Sep 2005
I have just bought a new house and the two front reception rooms have no rads. We want to install some but the system is Microbore. I am used to a different system. What will I need to do to install 2 new rads? Will I have to go back to the manifold to install 2 feeds and returns? I need some advise please.
how does microbore work? is it any different to other systems apart from the pipe diameter?
cheers
chris
its better to run from the manifold as u will get better peormance from the new rads.
the alternative is to extend an existing run/rad but it will be slower to warm up as it has to travel further in the small bore.
yes its the same as 22/15 mm pipe size but smaller bore.
the smaller bore can block easier but well maintained should be fine.
ur names not coldrick jamie peter ? is it.......
they are my initials u've nicked !!!!!
thanks for your responce very helpful, no my name is chris john pickard.
but thanks again, 1 other questions what would a resonable cost for installation?
cheers
chris
