Microcombi 23MFFI
7 Jul 2006
Hi, a problem with the Microcombi 23 MFFI, starts ok on CH but it goes to lock out after minuts, reset and the same, on HW the problem the same but I noticed the flame up and down and the clicking noise (ignition) on and off and then lock out, is it APS?
I would want a more detailed description of the problem with the exact times involved before even guessing what the problem is.
So far I am limited to guessing that it might be a CORGi problem
But temperature measurements within the boiler would also be useful.
Tony
Could be all sorts. Pump would be worth checking, if the boiler is getting hot.
checked the pump ok, the spark doesn't stop at all in both HW & CH the primary and water sensors measure ok about 12K cold and 3K hot, what do you think
