I have a microgenus 23 that works perfect on heating but when using the hot the temperature fluctuates. It gets very hot, cuts out goes almost cold and then fires up again to repeat the same process over and over. I recently replaced the diverter valve for another problem so its not that. Could it be the probes? Also, when it fires sometimes it buzzes momentarily. I dont think the 2 are linked though. Any thoughts would be appreciated to get this done as cheap as poss as it is going to be replaced this year when I do a loft conversion. Any thoughts on the worcester bosch combi? Thanks in advance. Steve
Just checked my receipts etc and I changed the dhw and ch temp probes with the diverter so prob not that either! Could it be safety cut out or would that send the boiler into shut down and need resetting?
