MICRON 40FF FAULT
12 Nov 2010
Staffordshire
Hi chaps
Just wondered if any one is familier with the gloworn micron 40ff
it was fitted around 2000 , the problem is that the boiler will turn on and work as usual but after the heating gets hot and assuming it as satisfied the thermister setting it turns its self off, also the heating does not seem to be overheating at all.
the boiler will then lock out and will not start again even when reset and the lights on front of boiler start flashing
the two GREEN lights at the front of the boiler flash or light as as follows
left hand light flashes slowly and the right hand light is lit but steady
the boiler as had a new PCB two months ago and a new air pressure switch, also the pump and 3 port valve seem to be working ok for both heating and hot water
The boiler will kick back in again after a few hours when things go cold then it repeats over again.
my thoughts were the thermister or the over heat stat perhaps
thanks guys for any suggestions or help
I find over 75% of the time its the Thermister. There are 2 different types on this boiler, so ensure your RGI gets the right one.
Mr. W.
if i remember that points to a pcb error.
I seco services I think you are right about the lighting sequence it does normaly point to the PCB but with the boiler having a new PCB two months ago it would seem strange
And yes misterdubya it would perhaps make sense to change the thermister first as it is the far cheaper option
Thx to both for your help chaps
