Just fitted a pcb to a glow worm micron 50FF due to the following:
Fan only starts up when spur fuse is switched off and then switched back on again. This happens even though the boiler control stat is switched off and then everything stops without firing. The led sequence points towards the thermistor led on left flashes slow led on right flashes fast. Both pcb's are the green light models.
The new pcb is showing the same led sequence though the fan does not even start this time . The new pcb has the turquoise spark unit fitted and I heard that the capacitor is not required with this pcb' can anyone confirm this please.
The jumper is on 1 and 2.
I am due to pick up a thermistor tomorrow as there was none avaiable today.
Any help much appreciated.
