Microwave power settings
24 Aug 2011
Hampshire
I have mislaid the manual of my 800w Hinari microwave. Model EMX710PSL. I have to microwave a car-dehumidifier when the sachet says it is saturated. It has to be at exactly 600w. The manual power settings on my Hinari are:
Low
Defrost
I M Low
II. Medium
III M High
IIII High
I can't find a website for Hinari.
I would be grateful for opinions.
STOP PRESS
My wife has just found the manual - in an obscure non-cooking place!
Problem solved.
Cheers
I thought whatever wattage a microwave is rated at, 800w in your case, that is the wattage power and is not variable. Those
settings only adjust the time it emits the power pulse.
I have a separate timer dial that is variable for what power setting you choose.
Unless the microwave is labeled as using "Inverter Technology", the way in which the lower Power is supplied is by switching the FULL Power on and off at suitable intervals. (One can usually tell this by listening to the sound made.)
