An aged relative has an AEG Combi microwave. She says it recently sparked a lot. On inspection I see it has an opalescent plastic "window" on the side wall (it is stainless lined). This is not for the interior lamp, which shines through holes in the sidewall. I presume it has the magnetron behind it. It is retained by two screws so presumably replacable.
This window had a brown burnt patch on it, I assumed it was a burned-on food splash and started to clean it all, but found the plastic window was cracked and brittle, and broke up as I rubbed it.
Is it likely that I can just get a new piece of plastic, or is the burnt window a bad sign?
I have the oven in the boot of my car but it's dark and raining so I haven't got the model no. to hand. but can get it tomorrow if it affects the advice.
