Mid port valve Honeywell V4073A. With heating off and water on (at the programmer) getting both hot water AND heating on (radiators are getting hot).
Took cover off valve and tried different settings. With fused switch off (cutting power to this part of electrical circuit) the valve moves under spring pressure, presumably to rest position. Turn on power and motor turns valve to a position - not sure which but can only assume A+B. No matter which combination is selected at the programmer (water on/off heating on/off) the valve does not move unless all power is cut. There is buzzing coming from the valve motor, like it is straining to move but can't.
I have only dealt with the V4043 before - that is a simple on/off operation.
Should the V4073 move to more than one position? If so, how much further to the next position? Do these symptoms point to a blocked valve? If so, can you remove the top plate on the valve to check/clear it?
