Hi Guys,
We have just replaced our boiler, rads and other parts of the system including the diverter.
The Valiant boiler (618 System boiler) we had installed has a setting where you can set the diverter to the mid-position when there is a call for heating and hot water. It is described in the VR65 manual. The boiler setting is d.70. (Note this is not the same setting as the filling setting where the boiler sets the diverter to the mid position allowing filling of both HW and CH sides)
Are there any issues in setting this?
The only reason why I am asking this is that at the moment we have the timer configured to heat the HW at a completely different time to the CH. If we set the timer to call CH and HW within the same period...
eg:
HW: 16:00 > 18:00
CH: 16:00 > 21:00
...this would then heat both equally and theoretically use less gas as you are not heating them at two different times. If the HW cylinder got up to temp, the diverter would then move to CH only.
Am I talking c**p or is there something in it?
Cheers
Ad.
eg:
HW: 16:00 > 18:00
CH: 16:00 > 21:00
Cheers
Ad.
