I have a small problem with the mid position valve fitted to our conventional heating system. The mechanism on top of the valve clicks when the central heating is switched on. In turn we get only hot water and no heat.
The motor inside is spinning but it seems the cogs underneath are just jumping rather than it changing position?
I presume a new valve is needed?
The current valve is a Honeywell V4073A however after searching today I could only get a Siemens 3PMP V22 from Wickes. The design of the new one is such that I will need to change the whole valve.
I'm fairly handy so have no real fears doing it myself, however I would like some direction on how to drain the system appropriately to change the valve over without getting a soaking. But at the same time I don't want to drain rads excessively unnecessarily.
