The middle single bath leg that you screw to the bottom of the bath fibre glass, with two small screws has fallen off when moving the bar. Will i be ok screwing it back on or will it not bite up as the whole is already there
Either move it over a tiny bit to make new fixings or glue some bits of used matchstick in the holes and then refix. Use the same screws to avoid penetrating the bath.
