Sorry to hear about that, my opinion is there's a problem with the flow meter either that it is faulty or that it is correctly registering too little flow. The latter seems unlikely given that you stated earlier on the inlet has been inspected. If the flow meter is faulty it could either be the PCB (which presumably can be checked with a magnet and multi meter) or its the waterwheel inside the inlet box
Service mode:
1. Open door
2. Switch off machine
3. Press and hold start/stop
4. Switch on machine
5. Release start/stop
6. Immediately press and release start/stop 3 times and on 3rd time hold it pressed in until start/stop flashes slowly.
Use delay start and intensive lower basket buttons to navigate options left and right, position 1 is fault memory showing saved codes if any codes. Use turbo button to select any sub options. (I've never owned this machine so assume those buttons all make sense to you!)
Fault code granularity might not help too much but let us know what you find.
