Miele dishwasher error code F79
24 Oct 2012
Cornwall
Error code F79 came up on a cycle that didn't even start.
I've scoured the web and can't find this code!
Any help please?
You will find very little Miele info online.
F79 signals a communication fault between the circulation motor frequency converter and control module.
Basically all you can do is check that the wiring between the circulation motor & pcb is intact (no broken wires/bad contacts). If ok then you need either a new circulation motor or a new pcb. Miele spares are very expensive, so rather than guessing which one to change out I would get a Miele tech in to pin it down first time around.
Brilliant, thank you very much for that!
I couldn't resist messing so I turned it off and on again (I'm more familiar with computers than dishwashers!) and it went through ok.
It's only about 10 days old so if it goes bonkers again, they can get round here especially considering what it cost!!!
Could the problem have been caused by a power fluctuation? We get them a lot here. They are noticeable but not enough to, say, reset the video clock.
If it is new you shouldn't be messing around with it at all...you risk invalidating your warranty altogether :(
Line fluctuation/surges can cause all kinds of problems. Keep an eye on it & if you get more error codes call Miele...
