Hi hoping for a bit of light shedding on my issue Ive searched hi and low but cant find solution to this issue
Dishwasher drains and fills ok then circulates on and off for about 5 mins in total then cuts out with i/d light
Drain pump ok /circulation pump stripped and ok /pressure switch stripped cleaned and meter tested ok with pressure/ float switch ok/ level switch continuity tested ok
the only fault I can find is that with machine on there is 240V at both pressure switch terminals on PCB all the time which is obviously wrong as one should be a switched live only with pump building up the relevant pressure can someone tell me if this is a PCB fault or some other glitch
Also in diagnostic mode I have a light at 9 oclock thats all
Im about stuffed with this fault about to ring Miele £117 callout!!! thanks Francis
