Miele G1022 - how do you access test mode?
19 Jun 2008
Bristol
Hello - Can someone help me sort out an issue with my Miele G1022 Dishwasher please?
When a programme is started, it takes in a bit of water and then stops after about two seconds. The drain/fill light flashes and more water is then taken in. Water is entering the machine.
I am suspecting a defective pressure switch and the machine is not detecting that water is entering the machine.
Can someone explain what the machine does at startup?
Is there a diagnostic mode that lets you manually operate the drain pump, fill valve etc?
Many thanks.
