We have a similar fault to that described elsewhere. Checked inlet and drain hoses, and the sump area. Impeller under the non-return valve looks clean and turns with the expected quarter-turn magnetic lump. Impeller just visible in the slot at the back also turns freely and looks clean.
Machine from switch-on does a drain cycle, I can see the water being pumped out swiftly. Fills, runs rinse cycle, then stops with red drain/inlet warning light on.
Followed error reporting procedure described here: //www.diynot.com/diy/threads/miele-dishwasher-problems-pressure-switch.307814/page-2
and have a 9 O'clock code. What does this signify please, @zipper and others?
