- Joined
- 22 Jun 2016
- Messages
- 4
- Reaction score
- 0
- Country
I have an elderly Miele W842 washing machine which has run perfectly for 17 years. Now the 'check inlet' light flashes on most washes, if I switch off and back on each time if flashes, 9 times out of 10 it will carry on and do the full cycle but occasionally it times out and empties the water - this happens on wash and first rinse cycles but NEVER on the final rinse.
I have checked hose and filters and flow up to the inlet valve is brilliant and suspect it is the inlet valve solenoid. I have the valve block off and run it into a measuring jug and the flow when on wash cycle is around 6 litres a minute - I am sure I read somewhere it should be much more.
Any suggestions please to confirm my suspicion?
