Miele T294C Dryer does not dry
22 Aug 2013
I have a Miele Dryer that suddenly no longer dries.
All it doe is blow cold air.
Can anyone help?
if its same set up as ours Novotronic T230 theres a non resettable thermostat on the back of the drum (access panel on rear) guess how that got fixed!!
My miele dryer had a similar problem. I removed the thermostat, banged it hard on a wooden surface and it worked fine.
Thanks for the replies.
It's now working fine, one of the relays in the small board, under the lid, at the back right hand side was not working, so I used the tried and tested method of hitting it to shock it into action. Great no cost solution!
