Purchased second hand tumble dryer off Ebay over a year ago - paid only £150 for what looked like a fairly new dryer. When it works, it's great but unfortunately it has been plagued with 2 problems. The first one is now fixed - the display would indicate that water reservoir was full despite the outlet pipe being connected directly to a drain. Turned out that the water pump which turns on and off periodically required lubrication. A small amount of 3 in one around the moving parts and I've never had this error message since (about 9 months).
Current problem is more challenging. I think that it is an overheating issue. Several things happen. Firstly the machine starts to groan once it's been running for a while. It's as if the motor is struggling to turn the drum. I think that this is due to thermal expansion. Next problem is regular non-specific error message (Technical Fault - call service, etc) and machine stops. Never gives more specific info such as error code. Most recent problem is TOC (thermal overload) has tripped twice. Fortunately, bashing on the ground trick has worked both times.
I've been reading other threads about Miele tumble dryer and it seems that it may be the rear NTC. In my machine, both produce a falling Ohms reading on heating but the rear one only goes down to 15 kOhms despite being immersed in boiling water. Front NTC gives appropriate readings (according to 'zipper') which is 15k at room temp to 1.5k at 85 C.
Just want to confirm that these NTCs which look very different (they are definitely both NTCs for sure) should give similar Ohms readings. If so I'll get a loan and buy a new one.
D.
D.
