Afternoon all
Problem with my Miele Novotronic 310 washing machine.
Water escapes from the detergent drawer and cascades down the front of my machine.
With no washing in the machine (as a test) I select 'Separate Rinse' and the water enters the machine via the detergent drawer with no problem.
When sufficient water is in the machine the water supply stops and the drum rotates. The pump eventually starts and empties the drum.
The pump switches off, the drum continues to rotate and the water supply begins again. THIS IS WHEN WATER IMMEDIATELY BEGINS TO ESCAPE FROM THE FRONT OF THE DETERGENT DRAWER.
I have thoroughly cleaned the inside of the detergent drawer and cjecked all hoses to remove any suspect restrictions.
Can anyone please offer a reason (and remedy) why the water flows into the machine via the detergent drawer initially but not when it automatically tries on a follow-up basis. I assume this demonstrates there is no blockage anywhere.
The problem only started today. At the end of a wash cycle there was a small amount of water on the floor (half a cup full) so I opened up the machine to check hoses etc and then tried the above
Any assistance will be much appreciated
