MIELE W3242 WASHING MACHINE
13 Sep 2014
Humberside
hi everyone ,can anyone tell me how to remove the front panel on a miele w3242 then i can take off the side panel to inspect the pump and pipe as i think there must be a blockage of sorts as the washing still comes out wet after spin cycle .water still pumps out from outlet pipe ok filter cleaned out , and it seems to spin ok ,
i have come to the following conclusions
1 could be slight blockage ,
2 pump worn out
3 motor not spinning at 1500 rpm
any ideas most appreciated thanks
Door open
Remove the rubber boot retainer and peel it off the front panel.
Remove the 2 screws around the door lock.
Remove the plastic plate at the bottom
There are 4 torx screws but only the outside ones need to be removed (2 in total)
Finally remove the bolt beneath the drum opening. Be careful as this is the only thing holding the front panel in place.
Thankyou RichardMNZ
job done found one of the pipes blocked my washing machine now back to it normal self [/img]
