I need to remove the pump,
How do I open the front panel that I belive is hinged on the left.
I have removed the four screws at the bottom,and the large bolt at the bottom of the porthole recess.
does the front control panel move with the front panel or should it be seperated.
If you have to remove the front control panel there is a retaining screw that is located behind the indicaton panel,and I do not see a way forward.
Help would be very much apreciated.
