Miele WPS leaking?
29 Jun 2013
We have a Miele DW that runs fine with no fault codes, but the WPS is leaking. The leak is not between the water line and WPS box but inside the WPS box itself.
I've checked the filter in the top of the WPS box and it is clear. The valve in the box seems to open and close properly and the machine reports no errors.
Might there be a way to a fix this WPS leak rather than replace the entire WPS?
Is there perhaps a gasket that may have worn through causing the leak?
Any ideas would be appreciated.
