also if your on mcb's you will have to think about the type of mcb your going to fit, type D's are the usual for welding appliances to allow for the large inrush currents although you may get away with type C's.
also as crafty pointed out, notifiable work. the circuit will have to be tested for compliance.
There is a chance that it will run off a 13Amp plug, though. Maybe someone with a similar machine will know. Welders have a reputation for start-up surges.
It will run on a 13amp plug, however it may blow when you turn up the amps on the welder.
Out of curiosity, I don't think you'd need a new circuit, couldn't you wire in a 16amp MCB off the current ringmain? then from the 16A mcb connect your 16 Amp ceeform
Alternatively install a 32Amp ceeform straight from the ringmain?
