Hello, I only recently qualified as a plumber, and I've not done any work on mild steel pipe, using a die to cut threads since my college days.
If I remember corectly, the method you use when making am joint is to,
1/ Cut your pipe, and use a die to cut a male thread into each end.
2/ Clean oil etc from the ends and apply Hawk White
3/ Wrap hemp in the direction of the thread (So in won't unwind while doing up the union?
4/ Maybe put on more hawkwhite??????
5/ Use a pair of steelsons to tighten up the coupling on the pipe.
Now please correct me if I've said anything wrong, I know you are not taught to use PTFE or the like. Only I've been putting hawkwhite on in spades, and I will be wet testing the installation tommorow and I'm sure its going to be a sprinkler system not a nice dry run of pipe. cheers fella's,
Danny
Danny
