- Joined
- 5 Jan 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi all and i hope someone can verify what im thinking is wrong.
Ok just before xmas i go to have a hot bath and theres no pressure at the taps.im running on economy 7 central heating with hot water cylinder.header in the attic.
If i blow down the sink hot tap water comes out of the hot tap in the bath....
Ive just gone into the attic and one of the black bage filled with itchy ass insulation, has fallen into the header barrel and emptied its guts inside, i mean the entire lot is in there.the only thing i could pull out is the bag.
Is the problem a blocked pipe which im really consdering is the cause of no hot water.however the cylinder is full of water and does get hot..
If my problem is a blocked pipe, how is my best way of getting the crap out the hot water system, shall i syphon the header then clean out the itchy ass stuff out of it and then drain my hot water cylinder and hope for the best,or am i looking at replacing the pipework,header and cylinder and also will my house insurance cover the cost of the job.
Why would the plumber not put a lid onto the header,especially knowing whats above it,and risk what could happen happening.do i need to call the plumber who did the boiler work as i still have his contact details.
Or am i barking up the wrong tree and the problem is something else.the way i thought it all worked was a expansion vessel in the attic fills with hot air, then that air forces the hot water down the pipes.however i was gutted that this isnt the case.as i was prepaired for that to have a hole in it therefore not expanding...
Ive turned the stop tap in the cylinder cupboard off that supplies the cylinder with water from up there,but no hot water is coming out the taps,is this the usual case when turning of this stop tap,or is this where the blockage is going to be,if so how is my best way to go about this.can i force air into the cylinder to clear the blockage or am i looking at taking the cylinder out and draining it.
lastly i have 2 bathrooms in my house 1 up one down.in the upstairs i have a electric power shower when i turn this on,it now screams is this because its full of insulation,as its direct fed from the header cylinder,and will it clear or is it knackered.Am i best off going through my insurance.
ANY HELP PLEASE I CAN FEEL A RIGHT NIGHT MARE ABOUT TO HAPPEN.
Please do not hijack posts. You can edit or "reply" to your earlier post to add more info
