Mini switches
16 May 2004
Bristol
Can someone please advise me on this one...
I wish to have lighting in a couple of built in wardrobes that is switched when the doors are opened/closed. Mini door switches such as tlc's push to break 'fm 142' seem to be the chaps. Do I have to provide additional forms of isolation or switching on the upstairs lighting circuit if I rebate these in the frames?
Would this application be better suited to elv lights with soft start bearing in mind the frequent switching (as I type this Im doubting the true 'frequency' involved- maybe the type of light is more suited to light up my hanging disco gladrags)?Obviously?!? switched on the 230 v side?
Thanks in advance, Mike.
i dont think you need additional isolation elsewhere, just the MCB, which should be off anyway for safety when changing bulbs ;) if you want you can have a normal switch hidden, for convenience when the bulb needs changing. No other reason to have one.
the 142s dont get recessed, they sit on the surface of the inside of the carcass, with the red bit pointing towards the door.
Yo - use these:
if you want recessed ones.
Personally I would go for additional isolation.
On a normal light you have a switch which will stay in the off position for maintenance. The jamb switches do not provide the same protection.
Play safe and add an isolator, cost minimal, safety maximum.
