minibus side windows leaking
6 Feb 2005
Hi
I have an ldv convoy minibus and the window on the off-side of the vehicle leaks when i'm driving in wet weather.I've tested the window with a hose pipe all over but no leaks.Any suggestions as to the cause of the problem. I'ts one solid unit with no openings.Thanks.
Just speculating, do LDV use plastic coated foam splash panels? My car developed a leak when I parked drivers door high towards the middle of the street. The water run down the inside of the door and through the foam panel at the bottom hence soggy carpets. The only reason I can imagine the panel got damaged is by water sitting on it and freezing in winter.
Awful vans.
Mine leaks like a sieve too, got plastic flooring so dont worry about it.
Think it blows in from the top of the door where they dont fit quite right!
Hi thanks for everyones help.The problem turned out to be errosion of the seal on the drip rail.Had it resealed and no more leaky windows.Hurray
