Hi.
I understand that there is a minimum brickwork width of 780mm at external corners to openings (if cavity of 100mm) - but is there also a minimum distance stipulated for walls adjoining existing brickwork tied in with wall starter kits to openings?
For additional info the wall is a non loadbearing wall of a single storey extension consisting of brickwork-100mm cavity-blockwork.
