Minimum distance from illuminated object
13 Jul 2008
Southampton
Possibly a silly question, but what does the phrase:
"Minimum distance from illuminated object" mean?
The luminaire manufacturer must make such a specification with reference to the maximum permissible wattage (W). Here the light emission angle of the lamp used and the nature of the object both play a role. Small or very small light emission angles require greater distances to the illuminated object, while shorter distances are sufficient for medium angles.
:D
It means that if you put it closer than that distance then the object may become dangerously hot or even catch fire.
So is it saying:
1. Downlight A must be X meters from another light.
or
2. Downlight A must be X meters away from anything it is lighting.
